Audiopipe AQX-3500.1 BänkTest
All I can say is HUH to this thread.
How did you test them. Did you use a true RMS meter. To measure amps voltage. What was your IMP rise to. What did your eletrical consist of.
Did you just clamp them or did you use an oscope as well? I'd like to see some THD numbers to accompany those ratings. Thanks for the post, though. I've been curious about those amps.
I'm very skeptical of these tests....2kw(50%) increase going from 12.5-14.7V? That's really hard to believe...not to mention doing 80% over rated on a 12V setup is pretty unheard of as well. THD through the roof, or not, I don't believe it.
Hi have test Audiopipe AQX 3500.1 in me Testbänk end a have get out ..singel amps
12.5 volt 1.1 ohm 4200 watt
14.7 volt 1.1 ohm 6240 watt
straped amps
11.5 volt 2.2 ohm 6420 watt
13.3 volt 2.2 ohm 9996 watt
this doesnt seem right 6 k at 14.7 volts at 1.1 ohm???? hmmmm if this is true this would be extriodinary!!
R4-junior
R4-junior
sweden
ninjawhiteboy12
