audiophile products
Spooby
Sound deadening screws...are they worth it?
They only work in conjunction with a sealed enclosure filled with audoiphile grade air. Oh, and you must have spent more than $3k on speaker wire and interconnects to be able to notice the difference. It is also recommended that you replace all the knobs in your car with wooden versions so the metal vibration doesn't introduce noise into your audio.
Thats the most absurd thing I've ever heard! //content.invisioncic.com/y282845/emoticons/furious.gif.fc81ca146dbff91fede3ed290dbc4f4c.gif
Wood knobs? They vibrate because they have a low fs. You must pull all the knobs out of yer car and replace them with sound-proof aproved ones. //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
aw crap.
ive got like 27 metal knobs!
how much do wood ones of the double wedge tri-saturated 3\8" quarter turn knobs cost?!? ill need a few wood versions of that. i got a few more too, but i dont remember the model numbers?!?!!!! //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
Blue could probably tell you all about those and what a super noticable difference they provide combined with his iridium triple lutz trapizoid coiled tweeter wire. Couple that to a quad saturation, high density, floating point, instabilium, copper plated deck reproduced from a circa 1996 unit and you will be king of the hill because items like this make such a HUGE difference in car audio and home!
Now when useing these screws, do not forget you must use a titanium cored, platinum plated phillips head bit attached to digital torque wrench set to 9 inch pounds. If you use an inferior bit or torque is off by even 1 inch pound, you overall stage height will be lowered 6.2325 inches.
Do not forget to insert 3.993mm x 25.113mm strips of hydrotaniation, rubbernized, medium Q, 85w90 strips in your doors that are imported from a underground lab in germany and developed in the first world war by top secret nazi scientists trying to eliminate sound waves coming from hitlers nasty farting problem when having an orgasm. If you do not do this, all will be for nothing because your system will sound "middle of the road" even if your cars idles at 95db.
Do not forget to insert 3.993mm x 25.113mm strips of hydrotaniation, rubbernized, medium Q, 85w90 strips in your doors that are imported from a underground lab in germany and developed in the first world war by top secret nazi scientists trying to eliminate hitlers nasty farting problem when having an orgasm. If you do not do this, all will be for nothing because your system will sound "middle of the road" even if your cars idles at 95db.
Oh shit, I totally forgot about the titanium cored, platinum plated phillips head bit //content.invisioncic.com/y282845/emoticons/banghead.gif.8606515f668c74f6de0281deb475b6fd.gif
Spooby
Spooby
PCS
Beat_Dominator
NorthFramingham
    Jun 30, 2026
