Conductor materials
Of the metals commonly used for conductors, copper has the highest conductivity. Silver is more conductive, but due to cost it is not practical except as a thin plating to mitigate skin effect losses at high frequencies. Because of its ease of connection by soldering or clamping, copper is still the most common choice for most light-gauge wires.
Compared to copper, aluminium has worse conductivity per unit volume, but better conductivity per unit weight. In many cases, weight is more important than volume making aluminium the 'best' conductor material for certain applications. For example, it is commonly used for large-scale power distribution conductors such as overhead power lines. In many such cases, aluminium is used over a steel core that provides much greater tensile strength than would the aluminium alone [1][2].
Gold is occasionally used for very fine wires such as those used to wire bond integrated circuits to their lead frames. The contacts in electrical connectors are also commonly gold plated or gold flashed (over nickel). Contrary to popular belief, this is not done because gold is a better conductor; it isn't. Instead, it is done because gold is very resistant to the surface corrosion that is commonly suffered by copper, silver, or tin/lead alloys. This corrosion would have a very detrimental effect on connection quality over time; gold-plating avoids that.
