Audiocontrol DQT EQ
Joebobclark
Your Moms New Boyfriend
1. Product:
Audiocontrol DQT EQ
2. Specs:
dual 30-band mono equalizers, plus two 2-band parametric EQs
24-bit analog-to-digital and digital-to-analog converters
stores eight equalization settings (settings will stay if you lose power)
2-channel inputs and outputs (with level controls)
top-mounted controls for easy adjustment
balanced inputs eliminate noise (switchable to unbalanced)
30 bands of equalization per channel (1/3 octave centers from 25 to 20,000 Hz)
2 bands of parametric equalization (adjustable from 25 to 20,000 Hz)
frequency response: 10 to 22,000 Hz
signal-to-noise ratio: 105 dB at full output
maximum output level: 7.5 volts
fuse rating: 2 amps
dimensions: 7"H x 9-15/16"W x 1-1/4"D
weight: 3-1/2 pounds
3. Description/Condition:
Good used condition. Power connector included.
4. Price: :
$140 shipped
5. Pictures:
Joebobclark
Joebobclark
Milford, NH
bad @SS chevy
