AudioControl 3.1 Help Please
retrojordans
Kenwood DDX-6019 DVD Headunit
AudioControl 3.1
2 - 4 channel Mid/Highs Amps
1 - Sub amp
My question is; The Kenwood has a really nice network of HPF and LPF filters as well as a sweet 3 band parametric EQ Treble / Mid / Bass with nice Freq ranges...
The Kenwood has the 3 band EQ, at the same time it has 3 pre-outs. Does each pre-out correspond to a EQ band e.g. Pre-out #1 - Amp 1/3 - Treble... and so on..
Or do I just use any 1 of the head unit's 3 pre-outs to run to the 3.1 and the EQ will just tune the output signal regardless of what's attached to it?
Also does the AudioControl put out it's rated 9.5v to each preout...or is that number divided by all it's pre-outs.
Wheew if anyone has done something similar pleassse chime in.
you should just send that Three.1 to me as it's not gonna really benefit you that much. just use your headunits EQ setting as the Three.1 is meant more for headunits with out that processing ability.
retrojordans
retrojordans
Detroit
retrojordans
BP1Fanatic
BP1Fanatic
