Originally posted by LoneRanger shiva is nowhere near the 1200Q in SPL.....i don't care if the virgin mary herself came down and built your box for you, it wouldn't touch a properly installed 1200Q in SPL. however, if you like SQ, the shiva is the champion in that department. I don't know why people keep comparing these subs to each other....it's really not a good comparison at all. The way I see it, the shiva is a great sub for the price because it puts out decent SPL while maintaining a good bit of SQ, but it doesn't do either exceedingly well. The 'bahn is all out SPL, and probably about the loudest sub you'll find for $100-$150.....but you have to sacrifice a lot of SQ because of the heavy surround and cone.
If your old box is 2.5-5 cubic feet per sub, you're okay. If not, you're gonna need to get a new one to run the 'bahns. As far as power goes, they need at least 300w each to sound good, but will handle 1000+w of clean power each in a ported box.
Of course, you've done a proper, detailed head-to-head comparison on this matter to be able to say this right... //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
Needless to say, audiobahn's lack of T/S parameters, their bogus sensitivity ratings, the lack of surface area on the cone of the driver, gives me plenty of weight to say that this comparsion is invalid, and any attempt to say one is louder than the other is false until proper parameters are available, or proper testing has been done on both.
Identical install, identical power, identical mic placement. Otherwise, the virgin mary herself wouldn't make me believe your comparison.
You do realize I can dial in up to almost 12dB's of gain with a shiva, and five cubes... riiiight? Sound like total butt? You bet! Gets you to where you want to go though!
Eventually, you'll catch onto the idea that there is no SPL in a subwoofer, only in applications. Frequency response with a standard install may not *sound* proper to you, but that means absolutely nothing in terms of output. Simply by sitting here and comparing drivers, I'll say the shiva will walk all over that audiobahn in low wattage classes due to it's higher cone area, the reality that audiobahn's Sd is lower, their moving mass is like a ton of bricks, and I know their effiency ratings are bogus. In fact, I'll go as far to say they likely rated it at 2.83V/1m, with the coils @ 2 ohm, which would give it not 1 watt of reference power, but 4 watts, giving it a bogus 6db of gain that does not belong there.
Talking SPL is cheap. You can stare at the specifics of a driver all day long and never get close because things are being taken outside of their linear envelope, into realms that software cannot help. Seeing as how you can't even stare at audiobahn's specs because there are none to have, I'd say this is pretty much a pointless conversation.
