M mavster 10+ year member CarAudio.com Elite 1,052 0 New York, NY Sep 2, 2007 #1 AS the title says...is it dual 3ohm or dual 6ohm coils.. Thanks Click to read more...
ZeroSktr56 10+ year member poop 520 0 Des Moines, IA Sep 2, 2007 #3 http://www.audiobahn.com/Audiobahn06/pages/woofers.html That took approximately 4.8 seconds. learn to search.
Qbenjamin 10+ year member CarAudio.com Veteran 3,643 12 Braavos Sep 2, 2007 #4 Audiobahn ALUM10Q Main Features: 120 oz. Double Stacked Strontium Magnets Power Handling: 800 watts R.M.S. Frequency Response: 20Hz 500Hz Efficiency: 95.6dB PHAT 1.75" EPDM Rubber Surround Spun Aluminum Cone 3" 4-Layer ASV Voice Coil Dual 6 Ohm 3 Ohm or 12 Ohm Operation Mounting Dimensions: Depth; 5" Hole; 9 1/4" Diameter; 10 7/8" Multi-connect Lug Lock Terminals
Qbenjamin 10+ year member CarAudio.com Veteran 3,643 12 Braavos Sep 2, 2007 #5 I did a 5 sec google search also. Learn to use it.
OP M mavster 10+ year member CarAudio.com Elite 1,052 0 New York, NY Sep 2, 2007 Thread Starter #6 I did...but I was getting conflicting answers...i need a tie breaker
Qbenjamin 10+ year member CarAudio.com Veteran 3,643 12 Braavos Sep 2, 2007 #7 It's a dual 6 ohm. Your wiring option's with a single driver are 3 or 12 ohm operation.
