cthedinger
Subwoofers are do in stock around November 10th. All prices will be plus shipping but will be doing free shipping for the first month or two. I will also be opening up a pre-order at the end of the week. I have 2000w (Exo) that will be here around the same. I also have a very underrated 800w sub in the works and am hoping to bring it out in the late winter.
Tropo-10D4 - 2” voice coil – MAP $89.99
Re: 8.0 ohms
Fs: 29.4 Hz
VAS: 46.1 L
Le: 2.87 mH
BL: 18.4 NA
Qes: 0..47
Qms: 4.82
Qts: 0.43
Mms: 106.7 g
RMS: 200 Watts
Tropo-12D4 – 2” voice coil – MAP $99.99
Re: 8.0 ohms
Fs: 32.3 Hz
VAS: 71.1 L
Le: 2.77 mH
BL: 17.2 NA
Qes: 0.68
Qms: 4.51
Qts: 0.59
Mms: 124.4 g
RMS: 200 Watts
Strato-10D2 – 2.5” voice coil – MAP $114.99
Re: 4.0 ohms
Fs: 34,2 Hz
VAS: 20.2 L
Le: 1.75 mH
BL: 15.4 NA
Qes: 0.47
Qms: 4.43
Qts: 0.43
Mms: 130.9 g
RMS: 400 Watts
Strato-10D4 – 2.5” voice coil – MAP $114.99
Re: 8.0 ohms
Fs: 32,1 Hz
VAS: 38.5 L
Le: 2.95 mH
BL: 19.3NA
Qes: 0.47
Qms: 4.15
Qts: 0.43
Mms: 107.1 g
RMS: 400 Watts
Strato-12D2 – 2.5” voice coil – MAP $139.99
Re: 4.0 ohms
Fs: 32.7 Hz
VAS: 112.7L
Le: 2.4 mH
BL: 16.5 NA
Qes: 0.56
Qms: 5.28
Qts: 0.52
Mms: 189.8 g
RMS: 400 Watts
Strato-12D4 – 2.5” voice coil – MAP $139.99
Re: 8.0 ohms
Fs: 31.3 Hz
VAS: 68.1 L
Le: 3.43 mH
BL: 20.9NA
Qes: 0.5
Qms: 4.23
Qts: 0.45
Mms: 138.7 g
RMS: 400 Watts
Strato-15D2 – 2.5” voice coil – MAP $159.99
Re: 4.0 ohms
Fs: 34,2 Hz
VAS: 20.2 L
Le: 1.75 mH
BL: 15.4 NA
Qes: 0.47
Qms: 4.43
Qts: 0.43
Mms: 130.9 g
RMS: 400 Watts
Strato-15D4 - 2.5” voice coil – MAP $159.99
Re: 8.0 ohms
Fs: 33,2 Hz
VAS: 111.5 L
Le: 3.5 mH
BL: 21.3 NA
Qes: 0.69
Qms: 5.02
Qts: 0.60
Mms: 187.1 g
RMS: 400 Watts
Strato-18D2 – 3” voice coil – MAP $189.99
Re: 4.0 ohms
Fs: 30.3 Hz
VAS: 205.1 L
Le: 2.01 mH
BL: 17.6 NAQes: 0.63
Qms: 6.76
Qts: 0.58
Mms: 254.5 g
RMS: 400 Watts
Strato-18D4 – 3” voice coil – MAP $189.99
Re: 8.0 ohms
Fs: 29.9 Hz
VAS: 187.2 L
Le: 2.38 mH
L: 20.4 NA
Qes: 0.78
Qms: 5.08
Qts: 0.68
Mms: 272.2 g
RMS: 400 Watts
Re: 8.0 ohms
Fs: 29.4 Hz
VAS: 46.1 L
Le: 2.87 mH
BL: 18.4 NA
Qes: 0..47
Qms: 4.82
Qts: 0.43
Mms: 106.7 g
RMS: 200 Watts
Re: 8.0 ohms
Fs: 32.3 Hz
VAS: 71.1 L
Le: 2.77 mH
BL: 17.2 NA
Qes: 0.68
Qms: 4.51
Qts: 0.59
Mms: 124.4 g
RMS: 200 Watts
Re: 4.0 ohms
Fs: 34,2 Hz
VAS: 20.2 L
Le: 1.75 mH
BL: 15.4 NA
Qes: 0.47
Qms: 4.43
Qts: 0.43
Mms: 130.9 g
RMS: 400 Watts
Re: 8.0 ohms
Fs: 32,1 Hz
VAS: 38.5 L
Le: 2.95 mH
BL: 19.3NA
Qes: 0.47
Qms: 4.15
Qts: 0.43
Mms: 107.1 g
RMS: 400 Watts
Re: 4.0 ohms
Fs: 32.7 Hz
VAS: 112.7L
Le: 2.4 mH
BL: 16.5 NA
Qes: 0.56
Qms: 5.28
Qts: 0.52
Mms: 189.8 g
RMS: 400 Watts
Re: 8.0 ohms
Fs: 31.3 Hz
VAS: 68.1 L
Le: 3.43 mH
BL: 20.9NA
Qes: 0.5
Qms: 4.23
Qts: 0.45
Mms: 138.7 g
RMS: 400 Watts
Re: 4.0 ohms
Fs: 34,2 Hz
VAS: 20.2 L
Le: 1.75 mH
BL: 15.4 NA
Qes: 0.47
Qms: 4.43
Qts: 0.43
Mms: 130.9 g
RMS: 400 Watts
Re: 8.0 ohms
Fs: 33,2 Hz
VAS: 111.5 L
Le: 3.5 mH
BL: 21.3 NA
Qes: 0.69
Qms: 5.02
Qts: 0.60
Mms: 187.1 g
RMS: 400 Watts
Re: 4.0 ohms
Fs: 30.3 Hz
VAS: 205.1 L
Le: 2.01 mH
Qms: 6.76
Qts: 0.58
Mms: 254.5 g
RMS: 400 Watts
Re: 8.0 ohms
Fs: 29.9 Hz
VAS: 187.2 L
Le: 2.38 mH
L: 20.4 NA
Qes: 0.78
Qms: 5.08
Qts: 0.68
Mms: 272.2 g
RMS: 400 Watts
