skibumdc
NOTE: I have already read the STICKY on deadening the door.
Ok, so I previously installed Polk Momo's 6.5 in the door of my 06 Audi on the plastic spacers.
About to swap those spacers for 3/4" MDF and clay it up...and I want to sound deaden the door as well.
The door from the factory already has some insulation on the inner door panel facing into the cabin...do I remove the old factory deadening and install the new deadening material then stick the factory stuff back on? Or get rid of the factory stuff altogether?
Only if I remove it will I see how sealed the door is...I'm betting the factory deadening is not tightly sealing the door since my midbass is not tight.
It's not a vapor barrier, it's foamy.
Thanks all.
Thanks all.
