Assembling/diassembling aeroports with flares question
95Prober
Hey guys
I installed a couple of 6" aeroports with flares on both ends. I may be building another and want to reuse them down the road I used the PVC cement/epoxy and Im sure it would be impossible to remove the flares from the actual tubing. So I assume Ill have to cut the center tube in half. Must I make the cut closest to one of the flared ends? If so, what should I use to reattach everything assuming the flares cant be taken apart?
Thanks
Yeah I know. I glued my flares on the ports per the instructions, but not I think I shouldnt have. I cant take them apart I believe now, correct?
I think duct tape would stick much better wouldnt it?
well if there pvc ports then that bond is solid and there is nowhere to take it apart at seeing as pvc cement turns the plastic to liquid form and allows the two pieces to bond, good news is if you cut it apart and put a couple reference marks to line the pieces back up the same glue that screwed you can save you use the pvc primer and a small amount of glue line up the marks then pull tape over the top and along the length of it to secure it while the cement sets up.
95Prober
95Prober
Canada
goingdef
