Arrrrghhhh
nawgee
I was driving last night bumping to some tunes when all of a sudden....MY WHOLE SYSTEM JUST CUT OFF!!! The HU is still on, my 4-channel amp is on....and my mono amp is on. What do you guys think could be the problem? My battery is reading 13.8v
Wait your WHOLE sytem shut off like speakers and sub? Cause I remember I was bumpin my sub like 3rd day I had it in and sub shutoff all of a sudden. My speaker wire had come out. Check that all wiring is connected since you say both your amps are still powered. It shouldnt be ground wire issue since the amps are still powering. Besides speaker wire, check your rca(s).
Are you running one rca to one amp then running an rca from that amp to the other? Or do you have individual rcas going to each amp? Cause I was going to say if its only one, maybe your rca came loose or something because that would cutoff the sound on both amps. That or both RCAs came loose at the same time somehow.
Update:
So I figured out the problem. =(
Apparently my fuse holder by my battery was bad. When I used my DMM on my amp I always had about 12v going to the amp. But if you wiggled the **** thing (fuse holder) it would sometimes only read 5v. The metal inside of the holder had this weird bend to it. I replaced the fuse holder and now everything works out fine. Thanks guys.
nawgee
nawgee
Valencia
Louisiana_CRX
