Are they any good????
audiobahnuser18
Need some help picking an amp the amplifier will be powering to audiobahn awc12t 2 12's 500 rms 4 dual ohm voice coil i been looking at these amps are they any good ? let me know Keep in mind the most i can spend is $200
Profile California AP1200
Peak Output Power(4 Ohms)-400W x 2
RMS Output Power(4 Ohms)-200W x 2
Peak Output Power(2 Ohms)-600W x 2
RMS Output Power(2 Ohms)-300W x 2
Bridged RMS Output Power(4 Ohms)-600W x 1
MOSFET Power Supply-Yes dual
Total Harmonic Distortion-
Signal/Noise Ratio-103 dB
High/Low Level Converter(Male RCA)-Yes
Pre-Amp(RCA) Outputs-Yes
Variable Bass Boost@45Hz-0-12 dB
12dB/Octave Crossover-HP/Full/LP
Variable LP Crossover Frequemcy-50 - 250 Hz
Variable HP Crossover Frequency-80 Hz -1.2 kHz
Bass Level Remote Control(16.4 ft)
Fuse(s)-3 X25A
Dimensions - 2"H x 10 1/4"D x 15 1/4"W
Power/Speaker Terminal Size(Gauge)4/6
Volfenhag ZX-8400
2000W Peak Power Handling
Tri-Mode Capability
2 Ohm Stereo
2 Channel Bridgeable Power Amplifier
RCA Input, Low & High by pressing one switch
RCA preamp line output
Selected x-over HPF/FULL/LPF
HPF: 50Hz-1KHz
Full: 15Hz-30Khz
LPF: 30 Hz-500Hz
Adjustable Input sensitivity
OdB & 18 dB Bass Boost
Remote Bass Control with 20ft Wire
2 Ohm Stereo / 4 Ohm Mono (45 Hz)
P.W.M MOSFET Power Supply
Soft Delayed Remote Turn on
Dual Color Indicator LED (Power and Protection)
Ultra Slim 1 1/4" Height easy installation
Blue Light Illuminated Right and Left Handles
Blue light illuminated Cooling Fans
Blue Light illuminated Terminals
Lanzar HTG244
2x250W RMS at 4 OHMS. 2x500W Max at 4 OHMS
1x1000W Max at 4 OHMS Bridged. 2x420W RMS at 2 OHMS
Electronic Crossover Network
Bass Boost Circuit
Bridgeable at 4 Ohms
2 Ohm Stereo Stable
Tri-Mode Capable
Gold RCA Inputs
Line Outs for Left and Right Channel
Low Pass Filter Controls
High Pass Filter Controls
Power and Protection LED Indicators
Soft Turn-on/Turn-off
THD: 90dB
Channel Separation: >65dB
Freq. Response: 10Hz~35KHz
Subwoofer Remote Level Control
Dimensions: 9.82"(W) x 2.34"(H) x 13.46"(L)
Lanzar Vibe 248
2 x 300 Watts RMS at 4 Ohms
2 x 600 Watts Max at 4 Ohms
1 x 1200 Watts Max at 4 Ohms Bridged
2 x 500 Watts at 2 Ohms
Bass Boost Circuit
2 Ohms Stereo Stable
Tri-Mode Capable
Gold RCA Inputs
Line Outs For Left & Right Channels.
Power & Protection LED Indicators
Advanced Protection Circuitry
Soft Turn On/Off
Remote Control Bass Booster
Frequency Response: 15 Hz - 35 kHz
S/N ratio: 90dB
Dimensions: 11.5"W x 2.3"H
These are some amps that i found on http://www.ikesound.com and they are in my price range but i was wondering if they were any good?//content.invisioncic.com/y282845/emoticons/uhoh.gif.c07307dd22ee7e63e22fc8e9c614d1fd.gif Pm me or post back ThX:veryhapp:
audiobahnuser18
audiobahnuser18
Mi
MisterGrubbs
Mike Mccabe
