I have 2 12'' RFR 1812 that are used.
http://www.fortunecity.com/skyscraper/black/438/rf/rfr1812.html
Model RFR-1812
Description 12" Punch Power Woofer
Nominal Impedance 8 ohms
Re
(DC Resistance) 7.08 ohms
Power Handling
(RMS/Peak) 600/1200 W
Sensitivity 88.0 dB
Fs 27 Hz
QMS 3.24
QES 0.51
QTS 0.44
Sd
(Cone Area) 83.71 in2
Vas 3.5 ft3
Xmax 0.4 in
Voice Coil Diameter 4 in
Mounting Depth 5-19/32 in
(14.21 cm)
so...what should i sell em for? (or keep em for a HT build as someone mentioned)
edit: will trade for an amp that does 1000rms @ 1ohm
Pics: If anyone wants my login name on a post it note next/on the subs just let me know. thats my hand you see regardless...also i didn't clean em up at all. both are tested and work flawlessly.
edit: i have refs on this forum and on others i can provide them if needed.
Model RFR-1812
Re
Power Handling
Sensitivity 88.0 dB
Fs 27 Hz
QMS 3.24
QES 0.51
QTS 0.44
Sd
Vas 3.5 ft3
Xmax 0.4 in
(14.21 cm)
