are there any secondskin promotional discounts for damplifier right now
Damp Pro Specs:
# 6.5 mil hard temper foil -BLACK# 2 mm total thickness (80 mils) +/- 5%
# Adhesive = Viscoelastic butyl rubber - 99.94% solids content
# .6 lbs per square foot +/- 5%
# 12" x 20" (1.67 sq ft.)
# High temperature butyl adhesive with increased elastomeric properties
# Higher rubber content - Less filler content = better performance
Damp Specs:
# Adhesive = Viscoelastic butyl rubber - 99.94% solids content# 1 mm total thickness (40 mils) +/- 5%
# .35 lbs per square foot +/- 5%
# 12" x 24" (2 sq ft.)
# Higher rubber content & Less filler content = better sound deadening performance
When it comes to automotive vibrtaion damping and sound deadening, Second Skin Damplifier is the best automotive CLD (constraint layer damper) in its class. No other CLD vehicle sound deadener is as afordable as Second Skin Damplifier. No other automotive sound deadener competes at this price point, and no other noise damping CLD mat to date, has a more proven track record for sound & noise reduction in automobiles!
Damp Pro is thicker foil and heavier overall.
perfecxionX
perfecxionX
indianapolis
whitedragon551
