Are the DMM's @ pep boys any good?
RJesus
pepboys sells a dmm for 13$, i was wondering if its any good? My dad has one but it measures on a line meter rather than with digital numbers.
The reason I ask this is because I googled DMM and things came up for like $200.
Will the pepboys one be accurate? //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
whats the difference between the 13$ one from pepboys and the 50$ one from sears?
Build quality, Parts quality, and durability. Accuracy also comes into question, but honestly the 50$ isn't going to be much more accurate. To get a fairly accurate reading your going to have spend at least 200 bucks.
i got mine from wallmart, 20 bucks or so. it has a yellow case. i wired 4 d-4 subs i was looking for a 2.67 ohm load ,when i tested it said 2.67.for the money i say get the one i have. if your looking to check voltage it does that just fine
If you have the money for the $50 one get it and keep it it should last a lifetime if not get the cheap one and itll do the same thing but might break in 5-10 years.
i got one of these. i like it because it closes up, protecting itself
$30 at http://www.radioshack.com/product/index.jsp?productId=2104114
its as accurate as my $150 oscope too
RJesus
RJesus
Philly
JimJ
