are capaitors worth it ????
kickerfan
18
ny
my question is i am building a system that is around 1400-1600 rms total between subs and highs and mids do i need a capaitor? if so how may farad is good enough? also whta does the volt surge mean? also who makes the best capacitor since price is no problem any help is appreciated guys-thanks rich
what is a batcap, what does it do? is it like a bigger version of a cap.
also i have seen those small kinetik batterys like the hc600 claim there better than 100 caps would that be a better choise than a 1 farad cap?
ive never gotta a direct answer on this either...Do batcaps do the same thing as a capacitor...
There are different batcaps that have different constructions, but hte basic idea is that they are simply batteries with a really high internal capacitance value. Pretty much any battery will have a much larger current storage than any cap, the difference lies in how fast it can discharge that current. An electrolytic capacitor can discharge the quickest, but it also has the smallest reserve. Again I must say that if you have to ask if they are worth it or not, the answer is in your case "no."
What is a BATCAP©?
A conventional battery, as we all know has a positive and negative terminal. The chemical reaction within creates
a flow of electrons, causing an electronic device (in this case an amplifier) to work. The stiffening capacitor is similar
to a battery in that it stores a charge. The fundamental difference is it cannot create electrons. It can only store and
supply (discharge) them upon demand. The advantage with a capacitor is that it discharges in one twenty thousandth
of a second, unlike a battery that does in one second. The battery therefore cannot discharge fast enough to effectively
supply the amplifier and this is the reason for "power sags."
hehee... off that site
but kinetik > batcaps.
x2, but i'd go with kinetik > batcaps > no cap at all > caps.
Since i installed my kinetik, even at idle, my voltage never drops below 14.3, even when i'm WOMPING on it with bass tracks, and i'm running ~2400w rms total system power, on TOP of car electronics, and my radio. (no headlights)
and i've got the highest output/lowest idle voltage iraggi alternator for my car.
i have the kinetik 800, btw.
local shop hooked me up cheaper than a 600.
kickerfan
kickerfan
ny
kickerfan
