Are Birthsheet Specs done with the Gain Setting maxed out?
You want to test the amplifier with maximum undistorted output...maybe you could get away with running with the gains cranked depending on the input signal. I wouldn't recommend it. But if you're benching it with an o'scope (I would assume), doesn't really matter as the scope will tell you exactly where to stop //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I would assume to meet CEA certification it's the max undistorted output...that would be the logical assumption.
But who knows //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
The answer is no, because an amplifier can reach full output with the gain set to minimum if the input voltage is high enough.
What Jack is saying is that the birthsheet figure is rated output into Xohm with X voltage input from the power source (probably 14.4V for CEA-2006). Whether the gain is set to maximum, minimum or anywhere in between depends on what the preamp input voltage is from the source unit.
Mr. Black
Mr. Black
Alberta, Canada
DBfan187
