Sold Arc, MB Quart, Memphis, etc.
Robertw813
Sold a few things from the previous post so throwing up the rest of it. Prices have also been lowered. Still not needing any trades on this stuff.
On to the good stuff:
Memphis CA300-4
75w x 4 @ 4ohm
115w x 4 @ 2ohm
230w x 2 @ 4ohm bridged
Worked like a champ until the day I pulled it out. Has general surface scratches but is in pretty good shape for a used amp.
$125 shipped.
http://s39.photobucket.com/albums/e197/robertw813/?action=view&current=MemphisCA300-4.jpg
Arc Audio KAR 400.4
Test Results (taken from: http://www.carsound.com/articles/pub...nter_298.shtml)
Measured output power (At 14.4 Vdc less than 1% THD+Noise): 70.2 x 4 into 4 ohms, 124.2 x 4 into 2 ohms, 248.5 x 2 into 4 ohms bridged.
Measured Current Draw (At Max Power): 27.8 amps into 4 ohms stereo, 47.7 amps into 2-ohms stereo and 4 ohms bridged
Measure Amplifier Efficiency (At Max Power): 70% amps into 4 ohms stereo, 72% amps into 2 ohms stereo and 4 ohms bridged
Measure 1/3 Amplifier Efficiency: 32%
Signal-to-noise dBA (Reference 1 watt): 92 dBA
Rated OutOutput power: 50 watts x 4 @ 4 ohms, 90 watts x 4 @ 2 ohms, and 180 watts x 2 4 ohms bridged
Transient distortion: less than 0.1% @ 4 ohms
Frequency response: 20 Hz-20 KHz
S/N ratio(A wtg): greater than 95 dB
Bass boost: + 18 dB @45 Hz
Input sensitivity: 250 mV - 2.5 V
Crossover: 55 Hz-5.5 KHz variable 12 dB
Fuse: 40A x1
Dimensions: 13 inches x 8.5 inches x 2.5 inches
This as running my components and rear fill up until this weekend. Great amp that worked well in Arizona summers and Massachusetts winters. Very little cosmetic damage.
$185 shipped
http://s39.photobucket.com/albums/e197/robertw813/?action=view&current=ArcAudioKAR4004.jpg
Arc Audio KAR 900.1D
350w x 1 @ 4ohm
700w x 1 @ 2ohm
900w x 1 @ 1ohm.
This has been running an RLp-12 @ 2ohm for the last year. Great amp that has been through the same as my 400.4 Very little cosmetic damage. No bass knob with this amp.
$185 shipped.
http://s39.photobucket.com/albums/e197/robertw813/?action=view&current=ArcAudioKAR9001D.jpg
SoundStream Angina
100w x 1 @ 4ohm
200w x 2 @ 2ohm
Nice little amp for someone who wants to run a very small sub. Was actually used in my girlfriends car to run a single 8" RE sub. It's probably a 6.5/10 cosmetically and the level adjust knob managed to break somehow, but it still works fine and is completely turnable (you can see it in this picture).
$45 shipped
http://s39.photobucket.com/albums/e197/robertw813/?action=view&current=SoundstreamAngina.jpg
MB Quart PCE-216 Components
Frequency response 38-32,000 Hz
RMS Power handling: 130 watts
Max Power handling: 260 watts
Sensitivity 87 dB
Top-mount depth 2-1/2"
MB Quart PCE 216 Includes:
* 2 Midwoofers: PWE160
* 2 Tweeters w/Crossovers: PTE25
Had these installed in pods with the tweets flush mounted in my doors. Good mid bass on these and the tweets get REALLY loud if you are so inclined. I always kept them turned down pretty low. I have all the mounting equipment and grills that these came with (Mounting screws, bolts, etc. not included in pic).
$110 shipped
http://s39.photobucket.com/albums/e197/robertw813/?action=view&current=PCE-216.jpg
RE8 Dual 4 Ohm Subwoofer
175w RMS
Brand new, never used. Nice little subs with a good sound.
$50 shipped
http://s39.photobucket.com/albums/e197/robertw813/?action=view&current=RE8s.jpg
I also have a RL-P 12" D4 for sale, but it would have to be somewhat local pickup as shipping is just to much... maybe. It's in great shape and I can get pictures if someone is interested in it. I'm looking for $150 plus actual shipping.
Robertw813
Robertw813
Boston, MA
blazen_indo
vegang
vegang
