Arc Audio Speakers
dinty01
160 deeeBeeeeess
Ok so I bought a set of arc audio kar series 5.25" components off of ebay, I finally had a nice day to install them and once I got them in and got them wired up, I turned my truck on and had some music playing and tuned them up a bit(I do need to go through the section on tuning your amp though, probably tomorrow), anyways I got it sounding good, and so I went to the state store to get some wine for dinner tomorrow night(makin dinner for the family) anyways, I needed to turn it up a bit and they started to stink, like they were maybe burning a bit? So I turned them down and drove with the windows down, on the way home same thing. I let the truck sit for a few hours and when I went out alittle bit ago they didnt really stink, any ideas what would cause this? they are being run by an arc audio 4150 xxk, i set up the crossover, nothing new there but not sure if I got a bad set of speakers or what? any help would be appreciated, TIA----Dinty
P.s. sorry to make that so long.
Could be one of two things;
1) A little bit of excess glue on the voice coil burning off if they were brand new. Nothing to concern yourself with.
2) You were thermally overdriving the speakers/clipping the amp and melting glue that shouldn't be burning off. This one you should worry about.
i think it may be option #1, their meant to run at 4 ohms and at 4 ohms this amp is supossed to put out 80 watts x 4, it may be alittle higher than that but the website also says the speakers can handle 50 watts normal power and 100 watts max power, is this too much maybe? I mean Im not beating the crap out of them and they do sound good but not quite as good as I thought they would of. Ive installed many sets of speakers and also amps before but I hadnt encountered this problem with any of arc's speakers before, hopefully its option #1 //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
well, i have the gain down as low as it will go since I wasnt sure where to go with it, and the music wasnt all that loud, Im gonna go work on it now and see how it sounds/smells
dinty01
160 deeeBeeeeess
dinty01
PA
dinty01
vegang
vegang
