Arc Audio KS1000.1 - Which IDmax? Dual 2 ohm or Dual 4 ohm?
jmass03
FL
Here are the specs on that KS1000.1:
Power output RMS @ 4 ohms: 1 x 850 watts
Power output RMS @ 2 ohms: 1 x 1000 watts
Power output RMS @ 1 ohm: 1 x 1000 watts
Transient Distortion (400W): Frequency Response: 20Hz - 250Hz
Signal to Noise Ratio (A wtg.): >112dB
Bass Boost: +15dB@10-125Hz
Crossover (Butterworth): 30Hz - 250Hz variable 24dB
Fuse: 30A x 2
Size: 15.0 1/2"(L) x 8.0"(W) x 2 3/8"(H)
I am going to be going with (1) 12 inch IDmax (still unsure about the type of enclosure, ported or sealed) but I will be using this amplifier. Could someone tell me which sub I need - the Dual 2 ohm or the Dual 4 ohm. I understand single voice coils, but am not familiar with dual voice coils. Thanks!
Two dual 4 ohm ID Max's will give you a 1 ohm final load with 1000w going into two subs.//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
jmass03
jmass03
FL
Maglite
