Sold Arc Audio 5150 XXK 5 channel and Eclipse EA4000 2/3/4 channel
jdubbau
Rating: 66.7%
4 2 0
ARC AUDIO 5150 XXK
In very very good shape cosmetically with littel to no scratches or marks at all. 10/10 functionality very high output for an amp of this size with a remarkable crisp sound. 1-4 channels for use for interior mids and high speakers and 1 sub channel that packs a pretty big punch for a 500 watt sub or so. This amp alone can run your whole system!!
$240 shipped CON US!!! OBO MAKE ONE
5-Channel Amplifier
RMS Power Rating:
4 ohms: 45 watts x 4 chan. + 190 watts x 1 sub channel (at 2 ohms)
2 ohms: 75 watts x 4 chan. + 190 watts x 1 sub channel (at 2 ohms)
4 ohms bridged: 150 watts x 2 chan. + 190 watts x 1 sub channel (at 2 ohms)
Remote bass boost control (0 - 18 dB @ 45Hz)
Variable Bass Boost Frequency: 30Hz - 125Hz
Designed, Engineered and Assembled in the USA
Various Protections: Short Circuit, thermal, reverse voltage, over voltage and DC offset
Built-in variable 12 dB per octave Crossover
12db or 24dB per octave subwoofer crossover
Crossover Range: 55Hz - 5.5kHz
CEA-2006 Compliant
Preamp output and Preamp input
Very high damping factors
4 gauge power/ground leads
Fully regulated power supplies produce full power output with battery voltages as low as 12 volts.
Symmetrical, discrete power amplifier circuitry
Engineered to drive highly reactive loads
Microprocessor controlled power supply and protection circuits
Dimensions: 16"L x 8"W x 3.35"H
Eclipse EA4000
8.5/10 Cosmetic if not better as I really do not see any marks on this thing at all. 10/10 fuctionality and crazy good sq and high output use as 2/3/4 channel amp.
$220 shipped CON US OBO MAKE ONE!!
400W Max, Integrated Series 4-Channel Amplifier
MOSFET Power Supply
RMS Power Output
4 ohms: 75 watts x 4 chan.
Bridged, 4 ohms: 150 watts x 2 chan.
High current, high-efficiency.
“Easy Tune” top-mounted controls.
Dimensions: 10-3/16"D x 13-3/8"W x 2-5/16"H
jdubbau
jdubbau
evansville In
jdubbau
