This is an awesome sounding sub, and is definitely a SQ sub. It shares the same motor as the famous Flatline series, not the other motor in the arc 12. D4 voice coil.
Impedance 2 or 8 ohm
Resonant frequency 20.5Hz
Sensitivity 89 db
RMS power handling 750 watts
Electrical "Q" .431
Mechanical "Q" 2.762
Total "Q" .373
Equivalent volume 9.88
One way linear 19 mm
Mounting depth 8"
Optimum sealed enclosure : 2.25 cuft
Ported enclosure : 3 cuft
Here is what a tech at ARC audio said about the ARC 15.
"Brian
The ARC 15 is based on the ARC Flat Line 12" motor (similar to the ID SPL) we use a poly cone rather then paper. The SQ is good but getting punch will require some careful box tuning. The 2.6 cu. ft box you have may actually work ok for this. I have attached a graph of your response curve and the recommended box curve. The 3.0 cu ft box goes a little deeper but that is about it.
I use 2 of the 15's in my car in 5.2 ported at 30Hz and it works fine. Goes deep but still has good attack. Most people are surprised it's 15's."
I had it in a box that was around 2.8net ported to 30hz, and i would say it would sound much nicer in about 3.5 cubes. Nice sq!
$140 shipped.
Sensitivity 89 db
Electrical "Q" .431
Total "Q" .373
Mounting depth 8"
"Brian
$140 shipped.
