Sold Arc 2500 xxk $180 shipped/TC motors cheap/Monitor 1 amps $90/$150 shipped
stupify
First of all I want to say that I know the pictures aren't that great and I'm sorry. I also want to say that all 3 amps look brand new and the pictures don’t show the true beauty.
Also why am I selling you ask? I'm not using any of it and want to build some HT towers that I'd use.
Monitor 1 amps
These were ARPA made. No crossovers
MK 4.70 (70x4, 220x2) $150.00 shipped
MK 2.70 (70x2, 220x1) $90.00 shipped
These are all cosmetically 9-9.5/10 The 4.70 needs two of the screws for the speaker terminals, but other wise is in great shape.
____________________________________________________
Arc Audio 2500 xxk amp $180.00 shipped
270x2 @4 ohms, 525x2 @2 ohms, & 1,050x1 @4 ohms bridged
# Highly efficent 4 layer PCB
# Uniquely designed high efficent power transformer
# Rated 500 amp power supply switching FET
# Rated 250 amp per channel output devices
# Variable speed fan control for quiet operation
# Power save mode for low level playing time with engine off
# Protection against: reverse voltage, over voltage, speaker short, and thermal overload
# Heavy duty construction
Amp goes straight into protect. It costs 150.00 from arc to get fixed. So you'd be paying $330 for this amp which is like brand new as the person I got it from Bought it new off ebay and it went straight into protection. He sold it to me as he didn't want to send it into arc and mess with everything. I just never got around to sending it in. I emailed the guys at Arc about getting it fixed and they can do it and its $150 shipped back. It still have the serial numbers etc on the bottom. I can send it right to Arc to save on the shipping as I would just have to leave a note in the box saying that its ok to send to the new buyer. I already talked to them about doing that and they didn't have a problem with that.
________________________________________________________
(2) TC sounds 2+ Motors $50 shipped each!!!
Both of the Motors have 8" baskets to go along with the motor. The baskets could use a repaint but aren't cracked and could be used again. Motor's were supposed to be for 10" or 12" subs but you can use them as 8's as they were custom drilled to make the baskets fit.
I got them from HawaiianBassHed who had them custom drilled so the 8" baskets would fit. TC or Scott at FI could recone them for you. I already talked to Kyle at TC and Scott at FI and both could be done for you.
I hope HawaiianBassHed doesn't get mad at me for using a couple of his pictures but here are the motors next to a DD 1008
Ref's are as follows
This is just a little of the references I have. This isn't getting into ebay or car forums
http://www.sounddomain.com/ubbthread...rue#Post969223
http://www.sounddomain.com/ubbthread...rue#Post975913
http://www.sounddomain.com/ubbthread...rue#Post975113
http://www.sounddomain.com/ubbthread...rue#Post973201
http://www.sounddomain.com/ubbthread...rue#Post972910
I've dealt with all these guys from Sounddomain/caraudio.com/diymobileaudio
dreid / Orange Foci
yosef
loud_aurora(x2)
SPLfreak
uiplannerman
Version 13
J37X
SteveC
this_forum_did_me_wrong
professional
Morris
blazedagain
*BowDown*
Goin' Def
its_hey_ma
TheGame420
Split2nd Racing
Renegadesrun
HCCAfan
OkMariner
vitveet(x3)
bigaztec
bkoopman1
vibrator
slow2.2sonoma
skinrock
Mazda3SQ
HawaiianBassHed
Mattz
http://www.caraudio.com/forum/showthread.php?t=145819
http://www.caraudio.com/forum/showthread.php?t=113112
http://www.caraudio.com/forum/showthread.php?t=111900
http://www.caraudio.com/forum/showthread.php?t=103339
I can get others if really needed
Prices again for those who can't read
Arc 2500xxk
$180 shipped
Monitor 1 amps
TC sound 2+ motor with basket
$45 shipped EACH
All prices are ship to the lower 48 only
does the motors have 3 in coils or 2.5
this is straight from TC's website
The TC2+ is our standard entry motor. Don't let our bigger motors fool you, The TC2+ will serve up massive amounts of output for its size and drive 12 even 15 inch cones with great efficiency. Subwoofers employing this motor typically embarrass others costing far more money. The secret is we simply don't use any cheaper parts to accommodate cheaper prices. We still provide a copper shorting ring, low carbon steel t-yoke and gap plate and twin 1" ferrite magnets with a wide 6.25" outside diameter. The TC2+ is designed to work with 2" voice coils and delivers BL Products exceeding 20 N*m. The TC2+ will perform diligently on 8", 10" and 12" drivers.
stupify
stupify
South Dakota
stupify
