1. Product:
Audioque 3500
2. Specs:
Specifications
Model AQ3500D.1
Digital Monoblock 1 ohm stable
Input Sensitivity 0.2V ~ 5V
Variable Low Pass Filter 20Hz ~ 200Hz @ 24dB/Slope
Subsonic Filter 10Hz ~ 50Hz @ 24dB/Slope
2 amp linkable connection Output Master / Input Slave
Remote Gain Control yes
Clipping Display Led yes
Signal to Noise Ratio 85dB
Damping Factor 250
Efficiency 85% at 4 ohm
External Fuse Rating 380 Amp in-line, 760 for pair
Tested Voltage 14.4V
Working Voltage 9.5V ~ 18.5V
4 ohm power @ 12V @ 1% THD 750W x 1
4 ohm power @ 14.4V @ 1% THD 1400W x 1
2 ohm power @ 14.4V @ 1% THD 2600W x 1
1 ohm power @ 14.4V @
1 ohm Power @ 16V @ 1% THD 5300W x 1
1 ohm Power @ 18V @ 1% THD 6000W x 1
1 ohm Power @ 18V @ 10% THD 7500W x 1
2 ohm Linked Power @ 14.4V @ 1% THD 8600W x 1
2 ohm Linked Power @ 16V @ 1% THD 10600W x 1
2 ohm Linked Power @ 18V @ 1% THD 12000W x 1
2 ohm Linked Power @ 18V @ 10% THD 15000W x 1
Dimensions (mm) 657.2mm (L) x 241.3mm (W) x 66.7mm (H)
Dimensions (in) 25.875in (L) x 9.5in (W) x 2.625in (H)
Power and Ground Inputs 0 Guage x 2
3. Description/Condition:
The amp is 3 months old. Cosmetically it is 9.8 out 10 and mechnically is 10 out of 10.
4. Price: :
price is 625 and no trades
5. Pictures: :
Audioque 3500
2. Specs:
Specifications
Model AQ3500D.1
Damping Factor 250
4. Price: :
5. Pictures: :
