aq2200
Honestly man, there is quite a bit of truth to what nG is saying. I'll tell ya what I know, but it isn't much. The power that the board makes is in between the DD M2 and the DD M3. Component wise it is supposed to be the best stuff that they have that will fit the board. DJ isn' the type of guy that is going to skimp $10 dollars on an amp, when it comes to quality. He might not put all the bell's and whistles on it, but he wants it to be reliable. It's comming from the same build house as the AQ 1200 and DD amps. I have 8 DD m1a's and 1 AQ 1200, and I haven't had a problem with any of them. I've been running the AQ 1200 since the day DJ received the first one, and so far it's been flawless. Past that I can't tell you anything really. I'm expecting a call from DJ any day telling me he has some in to play with. I'll let you know more then.
http://www.caraudio.com/forum/showthread.php?t=279633
If i also may add I posted the Actual Release date on the 2200... READ.....
The Knob is a really neat feature on the amp.... When you set the amp up via correct gain structure/ Lowpass/ SSF etc... You Plug this lil thing in and you have what is called an Actual Gain Control In which it adjusts the actual GAIN on the amp up or down REMOTELY... It IS NOT A BASS BOOST KNOB!!! lol... Say you have your gain set a 1/2 of the way up for example it will either increase or decrease the gain on the amp to the point were it is set and no more.... NICE!!!
The AQ2200D doesn't have the crap features like "BASS BOOST" Etc...
It has what all D class sub amps should have... A GAIN, CROSSOVER, and SSF...
That way you can spend the extra money on making the amp better or more eff. instead of wasting it on pointless and damaging Feature's a lot of people use that end up screwing shit up...
dadydolas
dadydolas
pitt. PA
BloWNMind
