AQ SDC2.5, AQ 1200D vids
I was also planning on getting the same exact sub, a single 12" setup as soon as they have them in stock. What enclosure are you using? And are you going for SQ or SPL or what?
How to edit MTS, M2TS, TS files on Mac?
There is an increasing complaints among camcorder users about the software that come with the camcorder which can't do the direct editing when they really need to, either because the files are too diverse, the file length is too long or the file quality is not so satisfory. Those who are racking their brains to work out a workaround will benefit from using MTS video editor for Mac.
MTS video editor for Mac is a versatile and powerful software, just as the similar softwares which can convert MTS file to the all kinds of file formats like AVI, WMV, MOV, MPG, MP4, MKV, FLV, SWF, 3GP etc, but the main point doesn't lie here.
MTS video editor for Mac is designed for those who want to edit videos, particularly for camcorder users, who frequently record videos, edit videos and convert videos in an all round way.
MTS video editor for Mac possesses richful editing features: You can adjust the aspect ratio or remove the black edges by crop function, cut unwanted frames of the file by trim function, adjust the effect of the file like Brightness Saturation and Contrast or apply special effect to the video if you want your video more artistic, or you can also merger several files into one if your files are too diverse. Furthermore, you can also do specific settings like Resolution, Frame Rate, Encoder and Bitrate for video, Sample Rate, Channel, Encoder and Bitrate for audio.
Step by step to edit MTS video on Mac
Step 1: Download and install MTS Video Converter for Mac
Free download the software and install it on the specific location on your computer, and then run a test. Please don't hesitate to contact us if there is any problem during the process.
Step 2: Load file
Click Add File on the top of the panel to import MTS file to edit, you are allowed to import a bundle of files at one time.
Step 3: Crop video
Click Crop on the top of the panel to pop up a Crop window, where you can crop the original file in the following two ways:
Setting aspect ratio: You can set the output aspect ratio from Zoom drop-down list, there are four options: Original. Full Screen, 16:9 and 4:3 at your selection.
Setting the values: You can type the value directly or set the value in Left, Right, Top and Bottom area to set the position of the cropping frame.
Step 4: Trim video
Click Trim on the top of the panel to pop up a Trim window, where you can cut the original file to a certain length, this can be realized by dragging the first slider to set the start time and the second slider to set the end time.
Step 5: Video effect
Click Effect on the top of the panel to set the video effect as you wish in the pop up Effect window: Brightness, Contrast and Saturation. You can also choose from the drop-down list of Effect to select a specific effect, either No Effect, Gray, Emboss or Old to add artistic effect to your file.
Step 6: Video settings
Click Settings on the bottom of the panel to pop up a Settings window where you can tweak Resolution, Encoder, Frame Rate and Bitrate of the original file.
After all the required settings have been done, click Convert to start converting automatically, wait for a while, you will get what you want.
They've been hooked up for over two weeks now. It's raining, so no vid today. They are loud, but sound great too. My box is 4 cubes net, 36 hz. I was going for a SQL setup, and these get plenty loud, but don't disappoint the SQ aspect. Also, the suspension is still a little tight, but a lot looser than out of the box.
AllenH427
AllenH427
Cincy Ohio
Immacomputer
