Notloud00
Quiet
hey do you guys think one of these can handle a aq1200d daily fine? also is 4 cubes @ 37hz with 2 6" aero sound like a good box design?
If you are only going to run one off the AQ1200 you will be showing the amp a 2 ohm load, perfect match.4 cubes at 38-40Hz is nice for daily. Short sessions at full tilt should be fine. Might want to call DJ and see what he thinks about running it daily off the 1200D.
Impressive subs...
so mechanically could it handle the aq1200 at 1ohm? or should i just run it at 2? also how do audioque subs play so low tuned that high? every box i have had has sounded like crap tuned like that.If you are only going to run one off the AQ1200 you will be showing the amp a 2 ohm load, perfect match.
They just don't require a low tuned box to drop low, trust me they get low //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gifyeah see how is that possible tuned to 38hz it just doesnt make sense
The AQ's smash my old MTX 9500's on the lows //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gifdo ur hdc3s play lower than ur mtx's? even tuned at 38?
