Sold AQ amp/2 custom 12s
lilkman2202
2 12" custom built subs
TC 9 motors
PG ti12 pro baskets
White nomex honeycomb cone
high roll rubber surround
d2 copper coils
direct leads
AQ4x90 amp
mint 100%
subs - 350shipped each
amp-180 shipped
inlcuded
no love? lots of views
Heres some love bro. These are absolutely beast and if i had cash i would take them back in a heartbeat!!
Theres not a single drop of ca glue on these either. Built completely with grey rubberized epoxy as compliant with tc sounds oem.
I added a polypropylene stiffing ring on the extended former for added strength and stability at high excursion. Also helps keep them linear. Single stiff spider, alum round coils that are .02" wider on od then the oem coils. Rms would be about 1500ea. Coil xmax is 23mm oneway.
Here's T/S parameters
12" ultratech blue monster
Taken in series
FS-31.63hz
QMS-4.862
QES-.5244
QTS- .4733
VAS- .9161cuft
RE-3.729ohms
LE-5.123mH
Zmax-38.31ohms
CMS-.07mm/N
MMS-370g
BL-22.87tm
SPL-83.84db 1W/1M
lilkman2202
lilkman2202
Milwaukee, WI
lilkman2202
