Aq 2200d
Anonymous
I have not been able to hook them up to my subs yet because when I was tuning them my neighbor came across the street being a dick but they seem to be very promising and powerful. Using my DMM, that has a clean power readout, to set the gains these things put out 56 clean AC volts. 56.7 to be exact so they should power my HD3's very very well. When I finish tuning them and get to actually hear the subs on these amps I will give a better update. That is all I have for now. If anyone else has more info on the performance please chime in.
just got done tuning the amps and let me tell you these things put out some power and for those of you that say they are the same amp of the hifonics bxi2607d it is not it is capable of much more power. I have the gains barely over halfway, each amp putting out 55 clean AC volts, they are capable of over 60 clean AC volts. They are much louder in the same setup than my 2 BXI2607's ever were. These amps easily do 2200 watts probably a little more. I am very very happy with them and the fact that they are under $400 dollars makes it really nice. Definately an amp more people should check into. Another quality product from AQ. Now I can not comment on reliabilty but they are very powerful
glad to see you like it.....Audioque puts out some very solid products and at a great price to boot //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
someone needs to do a strait drop from a bxi2607d and a AQ2200 with a termlab.
PSturmer I have used both of the amps the BXI2607 and AQ 2200 and the AQ pushes the subs harder than the Hifonics ever did. Also the AQ has more power to give, i have more power on tap if I need it. The Hifonics did not even put out the same amount of clean power as I what I have the AQ's set to now, and the AQ's can do more. Not taking anything away from the BXI2607 it is a very powerful amp and definately one hell of an upgrade for the Brutus line, but it is not an AQ 2200, even though both amps share the same boards the internals are not the same, they are not the same amp, the AQ is more powerful. I wish I had a TL to compare scores to convince you but maybe J25 can do that. I am looking forward to his test results.
Anonymous
Anonymous
Cantonment, FL
jnralp00
