Anyone here Suffer from Migranes?
Yeah i get them every once in a while. used the same stuff you used but the doc said to stop because they can increase your blood pressure and cause heart attacks...for me at least //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
Topamax daily, Relpax for bad ones that arise.
Topamax has not only decreased the frequency of which I get them (went from almost daily to maybe 1 every mo/every other mo), the ones I do get are not always day enders (or multiple day enders) like the ones before the meds were.
Relpax is super expensive, but it will cold clock any migraine within 30min with almost no side effect. Go to a doc and see if you can test these out to see if they work for you.
could mine be a pinched nerve or something? it feels like i have a normal migraine, but if i turn my head to the left i get a pain in the back of my head and partially down the back of my neck... hmmm
That's fairly common with migraines. A normal headache occurs from constricted blood veins causing a lack of oxygenation to the brain. A migraine often occurs with both swollen veins, as well as increased blood pressure. This is the cause for the much more intense pain, as the veins often put pressure on the grey and white matter of the brain.
Two large veins exiting blood flow from the brain back to the heart come through the 'back' of the neck and are close to the surface (much like the jugular in the front) and are often the cause of the neck pain that almost feels like a pinched nerve or severely stressed muscle. As a temporary relief, dark rooms with no noise, as well as direct pressure and hot/cold alternating rags tend to help some.
Imtjnotu
Me Gusta Edition
Imtjnotu
San Diego CA
Serpent710
