outbacksport
Found this amp at http://www.infinitecaraudio.com/cgi-bin/icastore.cgi?user_action=detail&catalogno=MK470,
They say that they are made by the same manufacturer who makes zapco.
Monitor 1 MK4.70 - 4Ch Car Amplifier 70 Watts x 4 @ 4ohm Stereo RMS - Bridged 200Wx2 @ 4ohm Mono Raw Power
Specs:
Output Power (RMS)
Stereo @ 4 Ohm 70x4 Watts
Stereo @ 2 Ohm 100x2 Watts
Mono @ 4 Ohm 200x2 Watts
THD + Noise
4 Ohm 0.04%
2 Ohm 0.08%
Bandwidth: 5Hz-75kHz
Efficiency: 61%
S/N Ratio >100dB
Seperation >60dB
Damping (4 Ohm) >450
Input Type Isolated RCA
Input Sensitivity 200mV-2V
Input Impedance 10K Ohms
Minimum Load (Stereo) 2 Ohm
Idle Current 1.2 Amp
Dimensions 337x224x55
What do you think guys? Is this amp worth it?
Specs:
Output Power (RMS)
THD + Noise
4 Ohm 0.04%
2 Ohm 0.08%
Efficiency: 61%
S/N Ratio >100dB
Seperation >60dB
