Anyone have Fi's phone number?
They dont use phone to communicate, the minute they add the phone line they increase cost ALOT. B/c then scott has to waste his time answering your questions that could be answered on the forum //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
there is box recomendations on the forum
SSD Series:
Available options and what they do:
Flatwound coil (+$20) – The flatwire coil option simply helps the power handling of the sub. The coil has more surface area to dissipate heat and will take more power then the regular round wire coil that comes in the ‘stock’ version of the sub. This option will also make the sub tend to be more prone to ‘peaking’ for a budget daily driving sub where you don’t have to use a ton of power to get maximum output and sacrifice sound quality a little bit.
Copper coil (+$5) – The copper coil is a heavier coil and adds mass to the moving assembly. In comparison to the stock coil, or the flatwound coil, this has the smoothest transitions musically speaking. It is less likely to peak, and is a better overall sub for more Sound Quality based daily drivers.
Enclosures:
SSD 10 – We recommend using a sealed box in the neighborhood of .6-1 cubic feet of volume (after all displacements for those wondering).
Ported box we recommend using .9-1.5 cubic feet @ 33Hz (this is optimal in our eyes and to our ears, you can tune 31-35hz fine if you so please)
SSD 12 – We recommend using a sealed box in the neighborhood of .8-1.6 cubic feet of volume (after all displacements for those wondering). I personally recommend 1.1 cubic feet of volume for the copper coil option SSD.
Ported box we recommend using 1.8-2.5 cubic feet @ 33Hz (this is optimal in our eyes and to our ears, you can tune 31-35hz fine if you so please)
SSD 15 – Ported box we recommend using 3-4 cubic feet @ 33Hz (this is optimal in our eyes and to our ears, you can tune 31-35hz fine if you so please) We are currently doing testing for sealed boxes, and I will post information if we think that it is ok to use sealed. Otherwise at this point stick to a ported enclosure.
https://ssl.perfora.net/www.ficaraudio.com/sess/utn;jsessionid=154693f2789be0c/shopdata/index.shopscript
Amazing what Google can do. //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
But yeah, for some reason there isn't a contact number.//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
zomg!!!!!!11!!!!1 they do have a website. what would I have done without you?//content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
BTW, I dont have to search... its saved in my favs.
myspace
Captain_Ahab
BUCK FAMA
Captain_Ahab
Da Dirty Souf
Rawr-DQ
