bamaboy
War Eagle!!!
Constant 12V+ Red Ignition Switch Harness
Starter Yellow Ignition Switch Harness
Ignition Pink Ignition Switch Harness
Ignition 2 Green Ignition Switch Harness (BCM and PCM)
Ignition 3 Brown Ignition Switch Harness
Accessory Orange Ignition Switch Harness (Heat/AC)
Tach Purple/White Coil
Brake Switch White Brake Switch
Trunk Release Brown (-) Switch
Trunk Pin Orange/Black Trunk Light
Parking Lights Brown (+) Light Switch
Head Lamp Yellow (+) Light Switch
Door Trigger Green/Black Front Rear Blue/White Driver's Kick Diode Isolate
Door Lock Red/Black Driver's Kick Panel Double Pulse to Lock only
Door Unlock Orange/Black
Driver's Lock Gray Left Kick Panel
Driver's Unlock Tan Left Kick Panel
Passenger Unlock Tan Right Kick Panel
Horn Wire Black (-) Steering Column
Windows Up LF=Dark Blue, RF=Light Blue, LR=Dark Green, RR=Light Green
Windows Down LF=Brown, RF=Tan, LR=Purple, RR=Purple
going by this, how would you wire that up? just connect the two or what?
