Anyone benched a crunch gp 1500 ??
anything other than the gp3000d is rated max watts. I think the gp2500d only does ~1300 @ 1 ohm. I would expect ~750ish from the 1500
ehh well that will work for now i guess, im going to eventually go with the 3000pro. Anyone think that amp will be ok at .6 ohms or should i look elsewhere?
Originally posted by Team Livewire - Eric:[QB] OK! Let me give you just a little info on the crunch amps. The GP1500D and the 2500D are rated at Max power not rms. Also these amps are unregulated so the more voltage you give them, the more power you'll get (but they do have high voltage protection around 16.4 volts). The 1500 made 857 watts at 13 volts, but a whopping 1189 at 15.5 volts. This was at 1.1 ohm reactive and all of that power is usable. The GP2500D made 1328 watts at 12.8 volts and 1704 watts at 14.75. These test were also at a 1ohm reactive. So they do more than most people would expect. Oh! The cross-overs in these amps are incredible. They have really good control over your subs. I'll tell you about the 3000 later today! [/QB]
quoted from termpro
here is the thread http://audioforum.termpro.com/cgi-bin/ubb/ultimatebb.cgi?ubb=get_topic;f=20;t=013407
Thanks for that info! Helped a lot //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
no problem //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
flexxissues
Re/Fi Hybrids FTW!!
flexxissues
Pa
allout13
