Anybody have experience with messed up amps?
newb
my amp powers up, sends power to my subs, but it sounds like it's not sending enough power to my subs. the amp is rated at 1000watts @ 1ohm, it's a Nakamichi pa-8001, my subs, 2 12w6v2's are wired in parallel into a 1ohm load. I've tested the subs with a DMM to make sure they werent blown and they werent. Something's a little fishy here, because I just came back from switching the Nak amp with an Orion 600d, which puts out 600 watts @ 1ohm, and the subs pounded twice as loud as the Nak. So something is definitely wrong with the Nak.
Anyways, backstory to what happened to the Nak. A friend and I was installing my system, right when everything was done, my friend noticed that the Nak amp has a switch, Normal or Bridge mode, so my friend thought that it was supposed to be in Bridge mode, so my friend switched it over. I didnt know any better and I agreed with him, (he has more years of experience than I did). We turned the key to the On position, everything powered up but my freaking subs were distorting and the excursion on the subs were **** crazy. The excursion was so sick that I thought my subs were going to blow. I told my friend to turn it off because something was wrong. We checked everything again, made sure all connections were secure and where they should be and everything checked out. I finally came to my senses and pulled out the owners manual on the nak amp. I read through it and it stated specifically that Bridge mode is to be used only if I was to connect two Nak pa-8001 amps together to put out twice the power, kind of like a link between the two amps to act as one amp. So I was like "****" I switched it back to normal, we turned the ignition back on, and my subs were not hitting at all. At this time I thought my subs were blown, because the amp powered up fine, but my subs were barely moving. Anyways, this happened about 2 or 3 years ago, I just finally went out and tested it today. Although, I tested the subs out a long time ago. I was too lazy to do anything about it. //content.invisioncic.com/y282845/emoticons/*******.gif.a649d21efc0d1fd4890a6428166586c1.gif
The way I see it, if the board or one of caps was fried Im sure I would've saw smoke coming from the amp or there would've been a foul smell, indicating something was toast. And even then, if the amp was toast it shouldnt have powered on. //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
So Im asking if any of you guys know whats wrong with it.
Thanks!
newb
newb
los angles, ca
newb
