any1 know wat sup with the sound coming out of tweater when engine turn on
are your power cables ran with your rca's? that is the most common cause of engine noise. if not, i know that some of the newer amps, such as xtant have a switch on them that is designed to be used with newer engines. all i had to do with my boat to get rid of the engine noise was flip a switch on the amp.
Check to make sure none of your speaker wires are touching any metal part of your car, check to make sure all your grounds are solid, and like bri said, run your rcas on the other side of the car from your power wires if possible.
The term for this kinda noise is "ground loop", if you want to do a search on it.
Hey this same thing happens to be, it started when i put a blass blocker down by the kick panels, it now occured to me that it could be touching the car body. All the other connections are good. Power and RCA's are seperate. I'll tell you guys how it works out by tomorrow
Two most common causes of engine whine..
1. Run power and RCA separate.
2. Check all your grounds. Put sub amp and high amp ground as close together as possible, if not together.. cuts down on ground loop.
Nice to see any knowledgeable person in these forums, can never have too much. I’m new to this forum but have some pretty extensive home theater...
mdd99
mdd99
Los Angeles, CA
crhye250r
    May 22, 2024
    May 22, 2024
