Any Spl predictions?
@shredder2 are you just changing the coil is all? Any other soft part changes along with the recone ordered?
The same but in d1... it was 1 extra spider, I'm adding a larger Northstar as well... SMS Agm 220.
I got a set of those Gp terminals so why not.
I'll play with airspace once I start testing too.... might stay the same,  might not.
Everything is ordered... now the wait then finding motivation.
Ok. 1 additional spider more? How many was it before 2?  Do you think the stiffness or suspension limited a bit will keep your clamped power about the same for that box or just adding some additional assurance for the current setup? Just curious.
The same as previously... 2 spiders.
Same enclosure to start... we'll see.
I'm gonna test, test... no predictions at this point.
You should paint the inside of your box with fiberglass resin or at the minimum a heavy slathering of wood hardener. You can never have too rigid of a box when it comes to spl. I would have tried different orientations, sweeps and moved interior bits around first before doing a recone. Those are all freebies. I gained 1.8db from bumping up the gain to a soft clip (only advisable if you know what you're doing.)
You should build a new box. Woofer and port on same baffle. I never could get loud with sub up port back/port side. Always was louder when woofer and port is on the same baffle.
The enclosure is the most important part.
shredder2
CarAudio.com VIP
shredder2
Az
shredder2
