Any possible way?
heres an even better question. what amp is it? i cant say i recommend it, but i know of many 2 channel amps that arent rated at 2 ohms bridged but can usually handle it all day no problems.
I have a friend that has a Sony XM-1252GTR and I bridged it to Kicker L515 at a 2 ohm load and it's been running like that daily. The only thing I noticed is that will go into protect if you start clipping the signal. I do not recommend it, we just don't care if the amp craps out.
Its a CADENCE TXA300.2 600 WATT RMS
# 2 Ohm RMS Power: 2 x 300 Watts @ 13.8 Volts
# 4 Ohm RMS Power: 2 x 150 Watts @ 13.8 Volts
# 4 Ohm Bridged RMS Power: 1 x 600 Watts @ 13.8 Volts
# Frequency Response: 20Hz - 30kHz
# Damping Factor: >200 @ 100Hz
# S/N Ratio: >100 db
# Channel Seperation: >65dB
# Minimum THD:
IDK what some of this means but can i set it up in 2 channel for each dual coil and if so how do i do that?
Sorry for the double post, just still wondering how to set it up in 2 channel per voice coil to get close to the 600RMS
postive and negative of one coil to positive and negative of one channel, then ditto. but 4 ohms a channel or 8 ohms bridged is gonna sound the same. if your gonna push 2 ohms bridged, you can, just start with the gain very low and work your way up. HOPEFULLY, if it cant handle it, it will go into protection, then youll know and youll still have an amp. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
I tested it out at 2 ohms and played it for about 20 minutes, it was pretty hot.
Switched it to 8ohms and seems much better temp wise and still is decent bass
Also I touched the ground and it was really hot, should I switch it to a different place?
8 ohms is the safe route so good call. where is it grounded now? or did i miss that part? regardless, the frame of your car is the #1 spot. scrape the hell out of the spot til its nice and clean
exilekiller
exilekiller
Orlando
Mass Car Audio
