any loud chargers/300s out there?
Wagonized
Want to make one of these cars loud as possible on music without a wall. I do believe the rear seats fold down.
I'm thinkin 2 15s firing forward probably with an 8" aero between the two. Sealed off from the rest of the trunk.
Anybody have pics or info on the loudest non walled charger and 300s out there?
Thanks
I built a charger for a forum member awhile back. Originally a a BTL 18" w/ a 2kw USamps amp (cant remember the model).
Sub up, port to side around 6cuft in the trunk. Did 148+ and killed the lows.
How loud do you wanna get?
152 or 153 would be good enough for me id say.
I wouldnt necessarily do an 18 in a charger theres not enough air, heres mine with a 15 and it did a 150.
If i did it all over again and was looking for a 148 on tunes (i did a 147), id do two 12s on about 4k watts.
152/153 in a charger? Dream on, take out the back seat and wall it because your trying to put 10 pounds of **** in a 6 pound bag.
Also it helps if you mod the rear deck and cut a massive hole in it and then redo it in grill cloth when the seats are up.
I had alotta fun, but realistically a 152 on music wont happen without a wall and im sure im about to get flamed here... pm me if you have any questions
I'm not saying I want it to bassrace a 152 or 153 I'm sayin I want it tuned relatively low (34-38hz) and still burp 152 or 153. I think its quite possible.
Planning to run an SD 16kD on 16 volts with 6 D1000s and a 200+ amp alt. For woofers I'm leaning towards 2 warden neo 15s
Wagonized
Wagonized
Abbotsford, BC
Wagonized
