any good?
Its a very good SQL subwoofer, but I have not heard any SPL scores on it. It is a little pricey //content.invisioncic.com/y282845/emoticons/greedy.gif.5a53e6246569d7ab79867170f3b06629.gif
very nice woofer but they are correct when they say you can get better quality for the same price...if you want stictly SQ with good loudness then that will be good, but for the same money you can get a sub that'll (with the right install) sound just as clean but pound WWWWAAAYYY harder. brahma,XXX, 2 rl-p......the list goes on.......
for indo on those go to
http://www.reaudio.com
http://www.adireaudio.com
http://www.soundsplinters.com
it does have some very nice fetures, like the "Bottomless" Design, the voice coil wont hit the magnet from high excursion. then there's the QCA (Quick Change Assembly) i think you can order the parts and fix it at home " not sure though" then there is the Xmax:(one way) 1.75" ohhhhh nice. and it looks massive, may handle more then the 750 its rated at.
but then again, i haven't read any reviews.
1.75" may be Xmech, but not Xmax.
The Ti and Ti Pro are both what is called an LGLC. They have a 1.4" tall top plate and a 2.3" long voice coil. So, they have 11.4mm of overhang. Now that is NOT xmax. LGLC drivers have an xmax much higher than overhang. As you move towards SGLC drivers, you see less and less of a difference between Xmag and overhang. That is one reason overhang isn't a reliable xmax spec, because it does not necessarily reflect the linear output capability of the driver. It is just an arbitrary measurement, with no real ability to account for differences in motor topologies. Actual xmax on those drivers is around 23-24mm. Their xmag is double overhang.
http://forums.caraudio.com/vb/showthread.php?t=94002&highlight=Eclipse
If anybody would know, it would for sure be Warbleed........
96pfinderSE
96pfinderSE
Georgia
PowerNaudio
