Antifreeze leak?
first look at the drain plug on the radiator bottom corner, then look at the hoses two big ones on the radiator two small off the engine next look at the water pumps weep hole bottom side right behind the pulley next if it is the head it may not transfer into the oil with the engine cold remove the thermostat housing to allow coolant to flow freely now start the engine radiator cap off see if it bubbles while running as this indicates a leaking head gasket along w/white smoke(steam) from the exhaust possible to see coolant in the oil depends where on the block the gasket has failed just look at the easy stuff first and work your way back good luck there will be a lot of this:verymad:
over the past 10yrs or so i have replaced alot(25 or more) of heater control valves for leaking on ford explorers at the shaft on the valve,its the most common leak on these.look for a leak trail if its not leaking at the time you check it.may still be the leak you are looking for,just not leaking at the time.also look at the water pump because i have seen the pump fool people due to the A/F running down the front cover and back the oil pan then dripping off the corners in the rear:D
you obviously have never had a blown head gasket. you must have x-ray vision if you can see in each fin on a radiator. you will not have sludge in the radiator instead you get milky oil. first thing he should do is drive is car to see if smoke comes out like I said than do an oil change and see if the oil comes out milky.
I blew a ****ing head gasket a month ago and i had NO smoke and the radiator was completely filled with the sludge shit. The head gasket seals the head from the block and when it blows, you get a mixture of oil and antifreeze. Its in both the oil pan and the RADIATOR. The oil was milky but i noticed the shit in the radiator first. You dont have to see through the fins to see the shit, thats what the radiator cap is for .
Thanks for your opinion smart ***
the heater control valve leaking is a very common problem on these:D. ASE cert tech for 19yrs
Yep.
ASE's mean crap. Just means you past a test. congrats. No offense to you 1lowZ56tahoe
Better to have the piece of paper than nothing. It looks good on an appication or resume. Otherwise they aren't worth much.
i vote heater control valve
Very common on that vehicle.
Yep.
Are you sure. I have been told I will never get a job without them. Just went on two interviews and was offered both jobs. ASE's and Kiss my white ***. And todays world. Do you think ppl really care about if this or that shop has ASE techs no. I have told ppl countless times that they will be running on metal to metal breaks before the next oil change comes. And have been given the big fat no thanks I dont need that. They go to some half *** shop. They pad slap it and let the person go. Mam your tires are slicks. NA thats okay Im good. I like slipping and sliding in the rain. Just like there are no such thing as loyal costumers anymore. My boss think that his costumers go no other place then his. I laughed.
Yep.
Yeah they might some what get you the job. But being you really dont know how to work on a car in real life. They dont help you then. lol. Seen that many of times. No offense to anyone that have them ASE I do as well. But know they are worth shit in the real world.
Synyster97XLT
Reppin' the 304
Synyster97XLT
Charleston, West Virginia
audioatg
vegang
vegang
