Another... which amp(specs only thoe)
bigt
Amp A
# 900 x 1 Watts RMS @ 4ohms
# 1400 x 1 Watts RMS @ 2ohms
# 1800 x 1 Watts RMS @ 1ohm
# 2400 x 1 Watts Max @ 1ohm
• Hi Speed Digital Circuitry
• Fully Regulated PWM Power Supply
• Four Way Protection Circuit
• 1 Ohm Stable Stereo
• Bridging Synchronization
• Variable Low Pass 50Hz-150Hz
• Variable Subsonic Filter 15Hz-40hz
• Variable Subwoofer EQ @ 45Hz
• Phase Switch 0-180
• Remote Dash Mount Low Level Gain Control With Cable
• Frequency Response: 15Hz to 150hz
• S/N Ratio: 100 db
• THD: 0.5%
• System Distress Indicator
• Inputs Sensitivity: 200mv-8v
• Dual Mono Speaker Output Connectors
• Gold Plated Heavy Duty Power & Speaker Terminals
Amp B
* 1x800W RMS at 4 OHMS. 1x1400W Max at 2 OHMS
* 1x2000W at 1.3 OHMS
* Class-D Design
* MOSFET Switches to Maintain Rated Power Over A Wide Range of Battery Voltages
* Stiffly Regulated PWM-Type Power Supplies
* Low Pass Filter Adjustable (15Hz~150Hz,24dB/Octave)
* Variable Subsonic Filter (15Hz~40Hz,24dB/Octave)
* Remote Gain Control
* 1 Ohm Stable
* Glass Epoxy PCB With SMD Technology
* Gold Plated RCA Inputs
* Custom Terminal Block for Speaker Connections
* Thermal, Overload & Short Protection
* Phase Control 0-180 degree
* Input Impedance: 10K Ohms
* Soft Turn On/Off
* Heavy Duty Power Coated Heatsink
* THD: 0.1%. S/N RATIO: 90dB
* Input Sensitivity: 200mv~4V
* Freq. Response: 50Hz~150KHz
* Remote Bass Control
* Fuse: 30A x 4
* Dimensions: 9.82"(W) x 2.34"(H) x 15.16"(L)
Please reply if u know what ur talkin about //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I know their on the cheaper side but they are what im lookin for ($)
hmm specs on amp B seem to be a lanzar opti2000D and judging by a thread i just read i'm gonna guess amp a is a PA 2400 //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif imo it depends on the subs
Well, if he wants a blind test, i'm guessing they aren't the greatest amps. Since many crappy brands are widely known for inflating their ratings, i'd like to know the brands of both amps.
yeah ratings aren't much good if we don't know if it's a reputable brand. if it is infact what has been guessed i'd say nothing wrong with the PA. i loved my 3000 until this morning
bigt
bigt
USA
bigt
