another question about wiring
ructwenty2
ok, ive seen the diagrams for wiring two dual voice coil subs in parallel. my amp has two positive terminal and two negative terminals. so could i wire each sub in parallel separately. would i still get a one ohm load if the both subs have dual 4 ohm voice coils
Well obviously if you have two DVC 4-ohm subs..and you wire them to paralle u are going to get a 1-ohm of resistance..However, I dont think that you will be able to get a 1-ohm load if u wire each of the subs parallel separetly..I am just writing real quick so I havent had time to re-check that..But **** I would just wire the subs parallel to both of the subs off 1-one channel and then u know you are going to get a 1-ohm overall resistance! But I would re-check if I were you!
Blake
ructwenty2
ructwenty2
Brandon, MS
SoundsUnlimited
