Ampere Audio AA-7500.1
XplicitAudio
Pro Seller
Check out the preorder of the Ampere Audio AA-7500.1: Ampere Audio AA-7500.1 - Xplicit Audio
There will be a limited number produced for this run so get in line. Few features will include built in fan, Acrylic back plate for better cooling with a heatsink to match the rest of our current models. These amps are due end of January. This is the ETA so DO NOT pre-order if you cannot accept possible delays.
Every order comes with FREE dual inputs.
4OHM RMS POWER : 2200W x 1 @ 14.4v
2OHM RMS POWER : 4000W x 1 @ 14.4v
1OHM RMS POWER : 7500W x 1 @ 14.4v
18v capable
940mm (Length) x 264mm (Width) x 73mm (Height)
Pre-Order price $1,299
Week on delivery $1,499
Pre-order on the AA-7500.1 should start next week. There will be a limited number produced for this run so get in line. Few features will include built in fan, Acrylic back plate for better cooling with a heatsink to match the rest of our current models.
Write up/Clamp tests: My test: Ampere Audio 7500.1 - Car Audio Classifieds
That amp is longer than my Lanzar OPTI 11000D by an inch although mine is an inch wider. How much does it weigh around 50-55lbs? Almost similar to mine except for the buzz bars in the middle, looks like a tight amp.
XplicitAudio
Pro Seller
XplicitAudio
United States
andrew2944r
