Amperage draw for Crunch GP3000D-Pro (Cant find manual)
Jeepjones85
Gold Power
I have decided to go with the Crunch GP3000D-Pro and mabe later upgrade
to a Sundown or DD-M3. Anyway what is the amp draw for the Crunch??
I was trying to see the difference between the DDm3 and the Crunch
Not the quality just the Amperage...I talked to the local DD audio dealer and
he told me the M3 would draw about 300amps
I tried to find the manual for the Crunch on there web sight but I dont see It
Listed anywhere, Iv looked at a few of the pdf files but I dont feel like looking
through all of them. Mabe I messed something:confused: Here is the sight
http://www.maxxsonics.net/manuals/crunch/
I looked at the owners manual and it doesnt say how much amps it draws at 1, 2 or 4 ohm loads... Calls for a 300 amp exteranl fuse. So take that into consideration. Like I said before some place around 300 amps. depending on ohm load and What music you listen to. Its not always going to pull all the amps all the time. I seen your other post. Your stock GM alt should be fine. Upgrade your battery to a good all around batt and do big three and possible add a secound battery.
Yeah I was told by the DDaudio dealer for the DD-M3 I needed a Kinetik HC1800 for under
the hood and another Kinetik HC2000 in back
So that was why I was comparing amps...
I am planing on grounding everything and buyin two Kinetik HC1800 and run it like that for now
Does that sound like a plain??
Jeepjones85
Gold Power
Jeepjones85
South-East AR
audioarsonal
