Amp wont turn on.......has no power
Bro you need to get some 1/0 power wire for that. You have at least 200 amps of draw therefore id fuse somewhere along the lines of 150 amps. To do that you need ANL style fuses so I'd just upgrade to a nice 1/0 kit and do the big three and call it a day. I ran two opti2000d's at 1 ohm a piece on stock 50 amp alt and one battery and it worked out so you should be fine.
David (TeamPSI) did that for me //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
He did the big 3 with 1/0, 150a fuse, and replaced my power wire to 1/0. At night i'll see how things are going, and if they dim I'll look into a battery because mines going to die soon anyway.
vids of the subs here
http://www.caraudio.com/forum/showthread.php?t=197682
ya I was running a Bx1500D with a 4 gauge and I had to use a 120amp fuse. Ur def gonna need at least a 120amp fuse. That 60 is way too small. And like they mentioned it should've probably been at least a 0 gauge, I think a 2 gauge would've been okay, but the 4 is way too small.
Also when u look at the fuse, like I said in my frist post. If the metal conductor in the middle is seperated (blown apart) its blown.
SlickCMRick
SlickCMRick
Las Vegas
phyphoestilic
