quins90lac
ok im going to hook up the 2 amps in my sig i all ready go one in and its got 4 awg running to it with a 100 amp fuse . so my question is when i go to hook up the other one could i just run some 1/0 awg to the back and then in to a splitter and have 1 4awg going to each amp with a 200 amp fuse in line from the battery ? Also can i run the wires off the same terminal that would have the alt positive wire for the big 3 . i was thinking about the 1/0 run cause then if i wanted to put in another battery it would already be in place and all i would have to do is run another one for the negative
