amp will not turn on!
  • 5
naw, i checked the ground and the ground was fine. i think my internals are bad on the amp or sumthin. i checked all the fuses too. i dont know. could it be blown?
I was mistaken, blue/white is the remote, solid blue would be power antenna //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif...
lmao hed be having bass to the radio and going wtf when he played a cd.... lmao
yall. I unplugged the radio harness and the antenna and plugged it all back in and it works. I guess its fixed… suppose it was the head unit...
802
YES.The Remote wire turns the amplifier On/and OFF. If you use a Toggle switch as stated, use one that Lights up so you know if its still ON or...
Well, I found a way to "fix" the popping. Ran a separate remote turn on from an acc fuse to turn on only the amps. Still using the LC7i GTO to...
  • Locked
185
Amp
244
ltj1121
ltj1121
FL
audiolife
    May 12, 2024
Brendon Jenness
    May 11, 2024
