lauf
We did a few tests in our comp car now keep in mind we had 17volt system.
The test
1 Beyond audio 18'' Inuman wired to 1.1ohm Aluminium
2 GNB 8volt wired to 16volt resting voltage 17volts
RE 35.1
We got 63 volts out of this one, we found it need alot of input voltage!
Visonik V900XD
70volts out of this one also liked alot of input voltage
EarthQuake D2 Fully Modded
80volts out of this guy, not as much input voltage as the others, when hooked up and just sitting there the tranistors made the loudest humming and buzzing noise I have ever heard from an amp, you can tell it's either going to put out some serious numbers or JUST BLOW UP either way not bad.
Also when burped the voltage spiked and dropped from 85 to 79 volts on each burp so after about .5 seconds the amp does not push full power, which I think is bad for these new mics.
Fusion JL1211D
93 volts out to place first place, you could notice each amp getting louder this one was easily the loudest for the RE to the Fusion it's like night and day. The fusion was modded to run at 1ohm and not shut down at 16.1volts everythign else was stock. Awsome amps also dampening factor is above 200 which is great for a Class D, we noticed the coils did not heat up as much and were more controlled with this amp.
We were using a Line Driver from Rw Audio
The gain was set about 1/3
The RE and Visonik peaked at 22vol on the deck
The Fusion and D2 peaked at 17vol on the deck
The test
RE 35.1
Visonik V900XD
Fusion JL1211D
