Amp Suggestions for RE XXX Plz
diehappy
I will be running a RE XXX 15 and would like to put about 1500 watts to it. I am looking for suggestions on what amp to run it with. Let me know. Thanks
Sub Specs:
Size: 15”(Dual 2 ohm)
• Dual Composite 2-piece Cone
• Rubber Surround
• Integrated Gasket
• Cast Aluminum Basket
• Tork-Tite Terminal
• 3” 4-layer Aluminum Voice Coil
• FEA Optimized Motor Structure
• Split Coil Design
• VMS Vented Magnet System
• Dual Progressive Spiders
• Integrated Tinsel Lead
Mounting Depth - 13.5"
Mounting Hole Diameter - 14.5"
Overall Diameter - 16"
Bolt Hole Circle - 15.25"
Motor Width - 10.5"
Motor Depth - 5"
Basket Depth - 8.5"
Displacement - 0.27 cu. ft.
Weight - 76 lbs
Electrical Q Value -Qes: 0.58
Mechanical Q Value -Qms: 3.62
Total Speaker Q Value -Qts: 0.501
Free Air Resonance -Fs: 19.10 Hz
Equivalent Compliance -Vas: 207.0 liters
One-Way, Linear Excursion -Xmax: 54 mm
Efficiency -SPL 1W/1m: 85.81 dB SPL
Effective Piston Area -Sd: 810 cm^2
DC Resistance -Re: 4.2 ohm
Nominal Impedance -Znom: Dual 2 ohm
Thermal Power Handling -Pe: 2000 W
Force Factor -Bl: 18.16
Hope that helps. It will also go in a box of about 4.0@33Hz . Might be bigger not sure as of yet. I am looking to push around 1500k to it.
Hm, I get alot of ppl telling me to get Sundown Saz1500 Interesting. And I have searched the forums. I am looking on mulitple forums looking for better idea's and the total outcome of suggestions.
diehappy
diehappy
Daytona Beach, FL
blackbonnie
